Mojack
Early A column for floor/console shift. If you've converted your column shift car to floor shift here's your chance to get rid of that annoying column mounted shifter nub. The upper collar is bent bad (maybe you could straighten it out), but what your after is the collar below that. I can remove it or send the whole column, your choice. $40+shipping from 37620. Thanks.
Oh, and the wires are a bit frayed, but could be repaired and used.
