stretch
I cut my cars!
I knew the right side floor had issues when I bought my Valiant. Its not as bad as I expected but its not as good as I had hoped. So the plasma cutter will be coming out as will the welder and spot weld cutting drills.
Have any of you replaced floor pans in your early A? If so, who makes the best fitting pans? I see AMD does not offer them. I also see the pans that are available are not full length. Just front and rear sections that require leaving the portion under the front seat.
My car had a rubber mat. I always assumed that a rubber floor would be better on the floor because water cant soak through it. It would apear that the water can't evaporate out from under it either.
