Early A material avail??
swing69
I’m just an old guy……
Central NJ
for a 65 Dart, I'll be looking for the 1/2 round padded, rope (or whatever you call it) for around the window/door frames. Is this stuff available at a decent price somewhere? I'm looking to do a 2 dr. post car.
Also: gonna need headliner material. any suggestions? source, quality?
it the silver/grey color for a 65 dart.
thanks.
thanks.
It's called windlace, and I got mine from RockAuto a couple of months ago. for my 2 door it was $105, minus a 5% discount code (search the web, they always seem to have one available), plus $11.50 shipping ($111 total). That was the cheapest I could find. Lots of colors available.
GOOD LUCK!
looks like Metro parts. I saw it on exterior, seals. It looks like its a round profile, black rubber on one side, webbing onthe other side. correct? how many linear feet for 104?
Ford MAC catalog has windlace at 2.25 per foot. its 1/2 round, fully covered and has a cloth "tab" the full length for mounting.
How does the metro stuff attache? thanks
I always get my soft products from Jeff Deutchmann at Deutchmann Automotive out of Bowling Green, OH. Not only does he have early A's himself, but his items are typically priced $5-10.00 cheaper than everyone else. His number can be found in the Mopar Collector's Guide, or other Mopar publications. Good luck with the early A, Geof
The best price I got on black windlace was from J.C. Whitney. It included the gasket material. All I had to do was pull the ratty stuff off, cut, and press on the new stuff. (Measure twice, cut once) As I recall JCW did not, at the time, have any other colors.
For the headliner, look at Legendary Auto Interiors.
https://www.legendaryautointeriors....l_allcatalog2.aspx?class=HL&year=65&desc=Dart
Made to fit, correct material for a lot less than a local shop would make up a vinyl, bow type headliner. If you don't see what you like, call them. They do custom work.
http://www.stockinteriors.com/Windlace.asp?Itemid=17825&MakeId=22&ModelId=371
Plymouth Valiant Windlace
Stock Interiors is proud to offer the highest quality reproduction Plymouth Valiant Windlace available. Our Reproduction Windlace is a woven fabric, sewn around a 1/2 inch foam rubber core, with a 3/4 inch flange for tacking. Occasionally it is necessary for the installer to sew strips of stiffener material (such as cardboard) to the flange.
We offer you the option to match your Windlace to your new Plymouth Valiant headliner material, but this requires that you order a headliner at the same time as your Windlace.Please note that the Windlace and headliner colors may NOT be a perfect match. If you want a contrasting color to your headliner, then please select the color you want from the list. If you have a white (or light color) vinyl headliner, we suggest matching the windlace to another interior color in your car (i.e. blue, green red)
Item: Windlace
Price Per Yard: $9.95
http://www.stockinteriors.com/items...MainCatId=17&Desc=Dodge_Dart_Weatherstripping
Dodge Dart Door Seals
18586 '73-'76 2- Door Hardtop or Coupe, Both Sides Door Seals $134.95
18584 '67-'72 2- Door Hardtop, Both Sides Door Seals $94.95
18588 '62-'66 2- Door Hardtop or Convertible, Both Sides Door Seals $174.95
18589 '62-'66 2- Door Hardtop or Convertible, Both Sides Door Seals $174.95
18590 '62-'66 2- Door Hardtop or Convertible, Both Sides Door Seals $174.95
18591 '62-'66 2- Door Hardtop or Convertible, Both Sides Door Seals $174.95
18592 '62-'66 2- Door Hardtop or Convertible, Both Sides Door Seals $174.95
18593 '62-'66 2- Door Hardtop or Convertible, Both Sides Door Seals $174.95
18594 '62-'66 2- Door Hardtop or Convertible, Both Sides Door Seals $174.95
18595 '62-'66 2- Door Hardtop or Convertible, Both Sides Door Seals $174.95
18596 '62-'66 2- Door Hardtop or Convertible, Both Sides Door Seals $174.95
18597 '62-'66 2- Door Hardtop or Convertible, Both Sides Door Seals $174.95
18598 '62-'66 2- Door Hardtop or Convertible, Both Sides Door Seals $174.95
18599 '62-'66 2- Door Sedan, Both Sides Door Seals $216.95
18600 '62-'66 2- Door Sedan, Both Sides Door Seals $216.95
18601 '62-'66 2- Door Sedan, Both Sides Door Seals $216.95
18602 '62-'66 2- Door Sedan, Both Sides Door Seals $216.95
18603 '62-'66 2- Door Sedan, Both Sides Door Seals $216.95
18604 '62-'66 2- Door Sedan, Both Sides Door Seals $216.95
18605 '62-'66 2- Door Sedan, Both Sides Door Seals $216.95
18606 '62-'66 2- Door Sedan, Both Sides Door Seals $216.95
18607 '62-'66 2- Door Sedan, Both Sides Door Seals $216.95
18608 '62-'66 2- Door Sedan, Both Sides Door Seals $216.95
18609 '62-'66 2- Door Sedan, Both Sides Door Seals $216.95
18610 '62-'66 4- Door Sedan, Both Sides Door Seals $184.95
18611 '62-'66 4- Door Sedan, Front, Both Sides Door Seals $184.95
18612 '62-'66 4- Door Sedan, Front, Both Sides Door Seals $184.95
18613 '62-'66 4- Door Sedan, Front, Both Sides Door Seals $184.95
18614 '62-'66 4- Door Sedan, Front, Both Sides Door Seals $184.95
18615 '62-'66 4- Door Sedan, Front, Both Sides Door Seals $184.95
18616 '62-'66 4- Door Sedan, Front, Both Sides Door Seals $184.95
18617 '62-'66 4- Door Sedan, Front, Both Sides Door Seals $184.95
18618 '62-'66 4- Door Sedan, Front, Both Sides Door Seals $184.95
18620 '62-'66 4- Door Sedan, Front, Both Sides Door Seals $184.95
18621 '62-'66 4- Door Sedan, Rear, Both Sides Door Seals $184.95
18622 '62-'66 4- Door Sedan, Rear, Both Sides Door Seals $184.95
18623 '62-'66 4- Door Sedan, Rear, Both Sides Door Seals $184.95
18624 '62-'66 4- Door Sedan, Rear, Both Sides Door Seals $184.95
18625 '62-'66 4- Door Sedan, Rear, Both Sides Door Seals $184.95
18626 '62-'66 4- Door Sedan, Rear, Both Sides Door Seals $184.95
18627 '62-'66 4- Door Sedan, Rear, Both Sides Door Seals $184.95
18628 '62-'66 4- Door Sedan, Rear, Both Sides Door Seals $184.95
18629 '62-'66 4- Door Sedan, Rear, Both Sides Door Seals $184.95
18630 '62-'66 4- Door Sedan, Rear, Both Sides Door Seals $184.95
18631 '62-'66 4- Door Sedan, Rear, Both Sides Door Seals $184.95
18619 '62-'66 Front Door, Both Sides Door Seals $184.95
Dodge Dart Window Seals
18151 '64-'66 2- door hardtops Flocked rear roll-up quarter window Window Seals $42.95
18150 '64-'66 2- door hardtops Rear roll-up quarter window Window Seals $25.95
18148 '62-'72 Real roll-up window Window Seals $18.95
18149 '62-'72 Rear roll-up window Window Seals $31.95
Dodge Dart Trunk Seals
