Early A Tie Rod and Sleeve Swap?
stop the beast
Arizona
I've read that the newer a-bodies can swap in 11/16 tie rods and sleeves from a C-body with no other modifications. Is this the case for early A bodies?
It appears to be. I just rebuilt my whole front end on my '65 Barracuda & used the 11/16" tie rod setup. The car is still sitting on jack stands so I have not driven it yet but everything went together fine. There is more info in this thread: http://www.forabodiesonly.com/mopar/showthread.php?t=129017
I do not claim to be an expert so take it for what it is worth. Hope it helps.
Well if it all bolted up okay and there's room for adjustment then it's worth a lot, thanks.
