whitepunkonnitro
This is everything you need to convert your 63-65 cable shift torqueflite equipped car to the later mechanical linkage trans using all factory parts.
Package consists of a manual column shift steering column, shifter bellcrank with all linkage, and the brackets that bolt to both the trans bellhousing and framerail. No more hunting for obscure, obsolete driveline stuff!
Asking $100 plus the ride. PM me if interested. Thanks FABO!
