[Found!] Early A Torsion Bar Adjusters
eekvonzipper
My Member is Legendary!
Cadet, Missouri
Anyone Have a Pair of the Adjuster Bolts with the Square Nut for the "D" shaped LCA?
I'm changing my Lca's for the the one's w/ sway bar tabs and stiffening plates...
but My old Lca's have Two different Adjuster styles One with Fine Thread and One with a Coarse Thread...
I'll take either or one of each Or just one. I guess it doesn't matter which as long as I have Two that match when I install.
Thanks to All!
Could I get a set from you?
I don't know which I would prefer...
Surprise Me!
If you have an oddball single one it would be perfect!
