[Found!] Early Barracuda Sway Bar Help
eekvonzipper
My Member is Legendary!
Cadet, Missouri
1st) Does anyone have a Stock Front Sway-Bar for an Early Barracuda For Sale?
2nd) Will it attach with the Pre-drilled Holes that I already have in My K-Frame?
3rd) Do I have the Correct LCA's to go with a Stock '65 Sway-Bar?
I was told My Recently Purchased LCA's we're '67&up?
Thanks to All!
Pretty sure you need to drill holes in the K frame for the swaybar brackets but that’s no problem....The early a-body has a unique sway bar, 65-66 only, 67 up is different but those 67 Lower control arms should work just fine with the tabs
The holes are there. Just add sway bar and brackets. Lower arms are good to go.
I just painted and re-installed my factory '65 sway bar (I previously retrofitted some aftermarket rubber bushings that fit under the brackets on the K-Frame):
