Early Barry Grant Alcohol car info needed
mikedevore
Oklahoma
I have what appears to be an earl B/G Alcohol carb , not a Demon B/G.
The numbers that are scribed on it sre JM964553 & below it is J52644.
It is supposed to be a 750CFM Alcohol carb.
I'm a little lost on one of these.
It looks like a Holley, but has the B/G center section & bowels.
The only alcohol carbs that I have worked on have been the Holley HP series.
They seem to do things different than the B/G.
What I really need to know is if the specs for this carb, ie jets, power valves, squirter size.
It came with 82 jets in the front & 87 jets in the rear. I noticed that it also has a hole drilled above all the jets going into where the jet screws in. I guess to richen it up further.
The Holleys use jets in the 132 & larger range, without extra holes in the mettering blocks.
This carb came with 30CC accel pumps & #25 squirters, again, the Holley stuff comes with 50CC pumps & squirters in the 55 range.
Since B/G is out of buisness & I can't find any info on the internet, unless its for the demon series carb, I was hoping somebody has tuned on one of these.
Any info is appreciated.
its not uncommon to drill one or two extra holes above each jet for more fuel... well alky
