[WANTED] Early MP Distributor "C" clip
zedman
Ottawa, Ontario CANADA
Rating - 0%
0   0   0
Yep that dam C-clip that holds down the upper distributor shaft went airborne and nowhere to he found. :(
Now go and try finding one! Can someone spare a couple of these odd ball clips?
PM me if you help.. Thx
Is it the one that is 3/4 round with 2 posts that are 90 deg to the 3/4 round part.
Yes Sir. It sits and holds in place the rotor shaft. Happen to have any?
You could probably get some spring wire, and make one but I'm sure one will turnup for you.
I had the same thing happen. I found it by taking the breaker plate off.
Buy a push magnet sold at Lowes to pick up nails. Push it around the shop. I find many things I am missing when I break that roller out. The problem I have now is my son doing machine work adds to the debris.
