mikeys toy
asshole
Will a 61 lf spindle/knuckle fit on a 62 lf?
If not, would a 68 dart’s with 9” brakes?
Are you sure? I always thought that all the 9" brake spindles would interchange. They all use the same hub and drum assembly, so, is it where they connect to the ball joint(s) where it's different?61 won’t fit 62 but the 68 will fit the 62
