Early V8 Gas Pedal Assembly
Eworth
Platteville
Is anyone reproducing the early V8 gas pedal assembly of bracket and pedal?
Putting 318 in my slant 6 1964 Dart. Gonna need it. Thanks
The pedal is being reproduced. You'll still have to source the hard plastic slide and pivot assembly. The bracket is not being reproduced and must be sourced used.
Dang. Thanks. The search for used parts begins ! Anyone have one? Will post in Parts Wanted also Thanks.
If not too particular, you can fit a 1967+ pedal w/ cable into an early A. I saw one in a ~1963 at PickNPull. Wasn't too pretty, they used maybe 2 of 3 mounting bolts, but I am sure it could be done nicer. Look for photos of an early A V-8 linkage. Unlike the rotating rod of slant six cars, it has a cable that comes off a plate that bolts to the horseshoe backed holes. The auto tranny kick-down is also special, w/ a linkage plate that bolts to the aft of the head, whereas slant cars take the kick-down off the rotating throttle rod.
Yes, sounds like a most cost effective approach. thanks. Whitepunknittro send me a message saying the same as you.
I'm approaching full meltdown on parts purchases ! :???:
