Eastwood 135 wire feed issues
pauly
MOPAR or no car!
Holton, Michigan
ive has my Eastwood 135 MIG for about 5 years trouble free. Changed the wire spool today and now can’t get it to feed. Anyone else experience this?
Same size wire as before? Does the wire feed motor run when you squeeze the trigger? Did you increase tension on the presser wheel? Is there a piece of wire still in the liner?
I figured it out, but it doesn’t make sense. Same size wire-no residual pieces of old wire. It would click when trigger was pulled, but wouldn’t rotate. I cycled the switch for the spool feed versus spool gun and the. It started working again.
