[FOR SALE] Edelbrock 1407 carburetor
texas360
TEXAS
Freshly rebuilt edelbrock 1407 carburetor. 750 cfm manual choke. Tested and box tuned. $180 shipped New it's over $300
Will trade for small block parts needed or 8.25 sure grip unit.
What small block parts are you looking for? I've got a few things.
I need valve Springs good for .500 lift, aluminum intake, valves, 1.88/1.60, 360 crank, oil pan for a 360 fit a 73 B body, windage tray with hardware, timing cover, non ac pulleys and brackets.
I'm sure there is other things. What you got?
Not much there. I do have some timing covers and might have some stock 340 valve springs (I'd have to search). I also might still have some original 340 valves (2.02/1.60). No 360 parts. The spare windage tray is with my spare 340. Can't really justify spending money for a carb at this point...
I have a new set of Comp valve springs, but I have no idea if they will work for you. 924-16. They are a single spring with damper.
I looked at the box wrong. They are 942-16.
The first number pulled up Springs for Chevy heads. The second number pulls up Springs for ford heads. The springs I need are 901-16. But new from comp they are only $50
I have a 360 crank if you still need it. It will need to be turned .010/.010 though.
