Edelbrock LD4B intake manifold
bkne543
Millbury, MA
Can anyone tell me if the Edelbrock LD4B intake manifold will fit on the early 273. I have a 1965 Barracuda with a 273 and want to change the 2 brl. manifold for a 4 brl. Will the LD4B work without modifications or do I need the D4B?
Thanks, any help would be much appreciated.
Bill K
Not without modification. The bolts are smaller for the earlier heads and at a different angle.
Or you can change the heads to 66 or later LA heads and run the LD4B...
Bkne, i used a performer intake, but i also have "302" swirl ports heads, the block is a 66 273, bolted up perfect, and runs like a ape!
Thanks for all the input. Now I have a much better understanding of what my options are.
Thank you guys for all your help.
Bill
