LJS30
What do you guys run with? In your opinions which carb is the way to go with a mild 360 build?
one of my friends has a edelbrock 750 on his old dodge 360 pickup
Well it looks like it's pretty much split right down the middle. I don't know guys, I am tempted on switching to an Edelbrock 650cfm on my 318 since this supposedly rebuilt T-Quad I bought is giving me all kinds of headaches.
T-quads need to be set up precisely. There are many items to look at even before tuning begins.
You mentioned a 360 and a 318.
Which engine is it going on ?
I would run a 600 Eddy on a mildly built 318. Works great.
On my mildly built 360 I run a 750 Eddy. Works great.
ive had more problems with eddys than anything else.not saying they are bad carbs,but they are not my first choice.a properly set up tq is great in,but takes some work to get it set up right.why not try a holley? jmo.
Right now I have a T-Quad on my 74 Dart with a mild 318. The issue is frustration mostly. It just seems like no matter what I do this carb along with the past T-Quad I had never ran correctly. I'm really thinking of going Edelbrock 600 as you stated. However, could it bolt onto a stock four barrel intake?
ive had a few as well....like i said im not saying they are junk,just not my first choice.the main problems ive had have been float related,stalling on braking ,flooding,cut out on cornering,and idle passage issues ,etc.some people may have had nothing but good results with them and bad results with tqs or holleys.run what you like,they all do the job when working correctly. myself , i like the eddy less than the others.problems with eddy;s like what problems ??????? I have had several and I mean several..... Don't judge them on getting a junk used one
Bear in mind that the newest TQ is about 30 years old, and almost all were installed on smog motors. That said, a good one is a great carb (Q-jets same way), BUT a piece of junk will give you no end of frustration. I've had my fill of used carbs. It's your money, but I'd suggest a new carb.
The Eddie AVS will bolt on to a square or spread bore.. We have one on a Performer for a 440, they are spread bore, no adapter plate.
I dont think people have mentioned this in this thread.
Is your remaining system solid? Electronic ignition, distributor, cap rotor plug wires plugs, coil, voltages at coil and ecm during operating conditions?
If you could find a properly tuned TQ they are pretty awesome and will work on a variety of size motors. In my perfect world I would have a TQ on my car and it would flow like 1000 cfm :-D
Anyway, if you simply want to bolt on a carb and not worry too much at all about working on it... ever, the Edelbrock AVS is the way to go.
My friend had a 650 edelbrock performer AFB carb. It seemed to be out of wack all the time, may have been operator error. Prob needed set up correctly. But I hated it when I bought his truck and switched back to a TQ that was in good shape.. AFB stands for Air Fire Backwards... :-D
Naw, some of thees fellows have some good stories about the Eddy afb as well..
I would select a carb that will suit you for a while towards the future, say, if you were going to build a mild 360 soon, then buy a carb that would work with the 318 and the 360 as well. Like a 650cfm or such.. With electric choke! That works perfectly on those carbs after a two minute adjustment.
Back a few (decades), I made the mistake of not planning for the future and purchased used carb a 600 carter (guaranteed to run great) for my 350 olds (and it did) the ( thecarb which I replaced on that engine was a quadrajet that poured gas out everywhere, shot fire out all orfices of my engine constantly and was setting fire to my car everytime I turned it off)..
So, shortly after that, I started running 455 olds motors constantly. I didn't have money to upgrade to the 750-800 cfm that I needed. I was poor as dirt, and the 455s were basically free back then.
So I ran them with my 600 carter.
So plan ahead if you buy a new carb.. I am not saying buy a 850 double pumper for your 318 because you may have a race engine 5 years from now, but just get a carb that will hold you for a little while.
Someone on this site recently mentioned these guys, I believe they will rebuild your TQ and or maybe set it up for you...
http://www.thermoquads.com/
May be an alternative to buying a new carb? Cost less? (not much) Halfway down the page the pricing starts.
I personally would only risk buying or investing in a modified TQ if I had extra money to try it, more for nostalgic reasons.
Is the Edelbrock AVS Thunder the carb you speak of? I was really thinking about buying one some time ago. This car is going to remain with the stock 1974 318 ignition, mild cam, manifolds, etc..... I'm not interested in shaving .005 off of my quarter mile since this is going to be strictly a street car. I just want a smooth running four barrel that will give me some fun from time to time.
