Dartswinger70
I have an Edelbrock performer series carb. If anyone is running this type of carb, what did you use to mount the throttle cable to the carb correctly. What I have at my disposal is: the carb cable stud from a Thermoquad (this doesn't fit the bracket on the carb, I would have to drill the carb bracket out). Or, a carb throttle cable stud from a carter 2 bbl . I think it may be a similar size stud, it sure looks the same, I haven't tried it yet. Does Edelbrock make a throttle cable stud and bracket kit for Small Block Mopar? if so what is the kit part number?
