femtnmax
Edelbrock #61779. Small block Performer RPM magnum style cylinder heads fully assembled. Valve stem to guide clearance was checked and adjusted as required prior to running the heads. These heads have been run about 3000 miles with a mild street cam. ARP 7/16 diameter rocker studs included along with Edel rocker studs & pushrod guide plates. I ran a different set of valve springs on them, but have reinstalled the Edel springs which have no miles on them. The intake port pushrod restrictions have been opened up; there are no leaks. These are more performance oriented than the build I had them on.
Heads have been cleaned, the orginal Edelbrock valve springs have been reinstalled. Will be shipped in the original boxes/packaging.
http://www.summitracing.com/parts/edl-61779
List for $790 each, asking $800 for the pair. My zip is 59715. Send me a PM on this forum. Thanks for looking.
I also have listed an Edel RPM air gap intake manifold to fit these heads. Comp Cam Pro Magnum full roller rocker arms (1.6 ratio) and Comp hardened pushrods to fit a flat tappet cam are also going to be sold, so could make a complete setup to install on top of your short block.
