cooooledart
How difficuly would all the wiring be to swap a 5.9 magnum into my slant 6 dart? What would I have to change?
Myself and Hotwire make the plug n play harness that you need. It can get a little overwhelming at time for people who are 100% comfortable with wiring and diagrams. I have to redo more people attempted harness' than anything. If you have a few Dodge wiring diagrams for your engine. The correct donor harness , the tools and the time. You can do it yourself.
You just have to weigh time and effort over cost.
There were times i wish i had.
We build both, depending on customers needs. I would guess 6-8 OBD II for every OBD I. We have two company's that flash for us . I believe one of them works with OBD I. If you plan on using larger heads and cam, I would stick with OBD II . There are a few more things for OBD II but not tons. You can get a bunch of HP out of both.
I wish I would have known about you guys a few years back. What do you guys charge for your OBDII harnesses?
