[WANTED] either a carter bbd or a holley 2280. no elec wires other than choke please, two vacuum ports please.
I have a bunch of BBD's of builder quality. There might be a Holley there too, I will need to check the box-o-carbs. And I'm local to you so likely no shipping needed. Shoot me a PM if youd like to discuss the details.
trhat would be great! i have a 1983 van with lean burn that has stopped working. which means i change out the dizzy to one with a vacuum advance. the current carb has no ports. let me know please.
almost forgot! thanks!!
hey we talked on the phone yesterday? i dont want to intrude on the holiday, however if you get achance can you see if you have the holley 2280 (or 2300)?
thanks man
talk later
I can check in the morning.
thanks man
talk later
Is this what you're in search of? I think I took it off my daily driver, 69 318 Dodge truck I had. $45 shipped to you! It worked fine & throttle shaft is not sloppy.
