Electric choke help
mopardemon340
WI
So need a little help adjusting my choke on my qf850. I press the throttle to give it a shot before start up and set the choke. When I crank it starts and runs for 30 seconds then Dies. Does that mean I need more or less choke.
Does it restart after that? Without hitting the gas pedal. Trial and error are easiest. 1 notch forward to backwards will ether fix the issue or make it worse.
