1966DartConvertible
Hi. I have just converted my '66 slant six mechanical fan to electric fan. Rite now im using a 185F/205F thermo switch for the fan i.e. The fan switch on at 205 deg and switch off at 185 deg. With this setup, the OEM temp gauge shows about 2/3 when the fan cuts in and about 1/2 when the fan cuts out. I dont know how accurate the temp gauge is, but I think I can trust the thermo switch. is it OK to run our slant six at 200F? Or would you suggest i use a 165/185F thermo switch instead? Thanks. Syed
