Electric fan Set ups
69dodgedart360
Milpitas
So now I am looking into electric cooling fans for the duster. Since I do not have a lot of clearance from the radiator and the water pump pulley I am unsure about which electric fans to go with. Has anyone used the Griffin 8-00038 radiator with an electric fan? Pictures? Part Numbers, advice?
Why not consider the electric water pump? My brother uses that plus you can run it when sitting with motor off to circulate things, hes drag strip crazy and it works for him.
