......or if you can weld aluminum, you can do it yourself.
Thanks for being decent man . I bought this car half finished put my motor and trans in it switched to an a833 8 and 8 3/4 . I believe the fell I got this thing from said that radiator was for a 70-72 and all I can figure is they move the radiator support rearward because of the stupid impact safety crap that came around in the early seventies no where can I find a 74 model year radiator even posted in the aftermarket online I got this rad with the car like I say
FWIW, I tried the electric fan route several years ago. I bought a Griffin Radiator with their electric fan setup. It just did not cool things off well. So I bought a stock shroud and went to a pulley driven fan blade. It works better than the electric setup. Now I am NOT saying that electric fan setups don't work, I am just saying that the setup I had was not working for me.
If you know an old time radiator shop, then can remove and manipulate the brackets in such a way as to move that radiator as far forward as possible. They could even raise the core up a tad, so that the top tank joint would be above that kicked back part of the support. That would allow you to move the radiator even further forward. Since you obviously cannot drive it to a shop, you're going to have to take very accurate measurements so they can get it right. It's damn near gonna be easier to just buy another radiator if you can swing it. ....and I fully agree that a two row with either 1" or 1.25" rows will not only probably cool better, but certainly fit better. Problem is, you're going to need to see HOW the brackets are welded on before you buy. It's a conundrum for sure.
Helioching is probably not the best option. Likely you can just bend the tabs flatter or cut them off and make your own brackets. I bought a two core radiator that just barely fit in between the rails and I measured the height and put the biggest radiator in there I could with the tanks on the side. It's kind of a Chevy style...
On the other note you might be able to loosen your motor mounts and your transmission mount and pry everything back just a quarter inch maybe get a little there....
I was just looking on summit racing and they do make electric fans 2 and 5/8 in thick.. if you can make just a half inch of room you'll be fine...
....and that right there is why these radiator companies should be a bit more specific. We simply don't have any extra room. I guess it's too much to ask to get something right. lolJust to clarify, all A-bodies, 67-76, have the same radiator and core support locations. Core support to fire wall is the same for all of them.
Yeah, Griffen's electric fan set up includes two Spal fans, that move a combined 1,694 cfm. That's about half the CFM you need to move to successfully cool one of these cars. The fact that they sell that as a combo for an A-body is darn near criminal, there's no way that would work.
Griffin ExactFit ComboUnit Radiator Details for - 1971 Dodge Demon PartNumber: CU-70154
By comparison, the Ford Contour fans I have on my car push ~3,000 cfm on low speed and about 5,000 cfm on high speed. Under 2,500 cfm isn't even worth trying.
Ouch. Yeah that's a problem.
You have to be careful even with the really thick two core radiators. For example, if the tubes are 1.25", that core will be more than 2.5" thick. Even with the core right up to the support that will be about all the space you have if you want to run a decent electric fan. The OE Contour set up I run is 3" deep in the middle, and 3.5" to the back of the motors. It's not the thinnest set up available, but it's not far off of it either...
Mig with a spool gun would probably work best I suppose.Helioching is probably not the best option. Likely you can just bend the tabs flatter or cut them off and make your own brackets. I bought a two core radiator that just barely fit in between the rails and I measured the height and put the biggest radiator in there I could with the tanks on the side. It's kind of a Chevy style...
I guess if it's narrow enough to fit tween the frame rails, yeah. It's just something you're gonna have to experiment with.Thanks for your help fellas . One more question. Will an e or b body radiator work in an a body
I agree. I had a very generous member GIVE me a factory 3 row radiator for Vixen. I had a 3 row chinkesium aluminum radiator in her.....and it cooled fine, but it was the ill fittinest sumbitch ever. This factory radiator is like a wet dream come true.Or....
You could get an OEM or OEM style copper brass rad and a factory style shroud and the correct fan, pulleys and water pump and not have any problems.
I figured this is where triple r would have went immediately...Or....
The op seems to want electric fans due to a fitment issue rather than a cooling issue.I figured this is where triple r would have went immediately
I don't have a customer that has points in their vehicle. Every one of them I've convinced to pitch those archaic points then put in some potronics or some kind of electronics ignition...The op seems to want electric fans due to a fitment issue rather than a cooling issue.
I for one have no problem with electric fans but like electronic ignition it adds a complexity that points and mechanical fans does not
And I paid through the nose for it.Yeah, Griffen's electric fan set up includes two Spal fans, that move a combined 1,694 cfm. That's about half the CFM you need to move to successfully cool one of these cars. The fact that they sell that as a combo for an A-body is darn near criminal, there's no way that would work.
I started to, but I'm kinda trying to give him some ideas to work with what he has. That seems to always be the most frugal route.I figured this is where triple r would have went immediately...
And people jump all over it since it's a name brand and they "think" it'll work. That's almost theft.Holy Crap!!! I just looked up that combo and Summit sells it for $1,633!!!
That’s nuts. That’s a cookie sheet with some flaps cut in it with some dramatically undersized 10” fans bolted to it. Like I said, 1,694 cfm is about half what you’d realistically need to be successful running electric fans as a standalone.
And Summit advertises that combo as only moving 1,498 cfm, so even less than what Griffin claims. There’s literally no way that would work. It’s even a 22” radiator.
I think when I bought my Champion 26” 3 core, the Dorman knock off of the Contour fans, and my fancy digital fan controller I was in it for under $600. The fans are still only $143. There are a lot of really expensive electric fans out there that won’t pull what the Contour fans are rated at.
I used a Chevy HHR fan on my 22” radiator setup that is really limited in space between the radiator and water pump.
I built this one probably six seven years ago for my duster. It was just the factory radiator and a piece of aluminum sheet metal I had where I measured it and bent the edges three quarters of an inch.. I think I got the fans for like 40 bucks from a member that used to be on a 440 motorhome engine?.. works fine for my 318 but when I got the stroker motor it just couldn't keep up... I've got it out in the shed I think I'm going to take it out here in the next week or so to reinstall it in my duster..
I actually put the right stuff silicone around the edges of it, it's sealed in very well..Heck that’s probably already a better set up than what Griffin is selling for $1,600. Maybe down on CFM if it wouldn’t keep up with the stroker, but it would be hard to be lower output than the Griffin set up.
