This gas is so bad and evaporates so fast, over night the carb is empty! electric is the only way to go, on a relay wired thru oil pressure switch, engine off, no pump. Ez to wire with a prime push button. safe IMO.
I keep a splash bottle handy. On Fridays I splash a tablespoon or so of gas down the primaries, get in, floor it, and hit the starter.Shazzam!!
The hard hot-start, as mentioned, is a separate issue.
Been running an electric pump on the street for years..never one issue.
I wouldent even consider an electric fuel pump without an inertia switch but I have a phobia about being the main attraction at a wiener roast . good luck .
