electric fuel pump ?
flathead31coupe
indianapolis indiana
when installing a holly fuel pump on the frame in front of the pass side tire its below the tank and using the factory fuel sending unit, which has the fuel line turned up, so the line would need to go up then down to the pump on the frame...if theses pumps like to push not pull..will that cause an issue...the sending unit also points down to the bottom of the tank, so it will still have to climb up and out.. thoughts...i know if you put fuel in the tank and dont have the line hooked fuel will run out of the sending unit...
if you run fuel lines like the factory did on a 65 dart, up and down to the sending unit nice and neat, to a electric fuel pump mounted on the lower pass side frame rail, will the pump have any trouble, it has to pump up then down to the pump..the factory sending is turned up on the fuel line.
It shouldn't be an issue. The important part is getting the pump below the fuel level. I believe from your description, you've done that.
