Electric water pump and a mini alternator?
dusterdoug
Tracy, CA
For those of you using a moroso (or like) water pump on a small block...
What brackets are you using for your alternator. Specifically a mini alternator.
Thanks!
For a small block, I fabricated my own. Took some trial-&-error, but lots of angles to consider. Not as much in belt options or adjustability as it turned out, but it works. It was hard to clear the radiator hose.
