I'm looking to go with an electric water pump for next racing season. I know Mezier makes a nice product, any other brands out there worthy?
I've been running the Summit one for the last year, absolutely no problems. On any of these pumps, don't count on the O rings to seal, you're going to need some RTV!I'm looking to go with an electric water pump for next racing season. I know Mezier makes a nice product, any other brands out there worthy?
What does your charging system consists of?I've been running the Summit one for the last year, absolutely no problems. On any of these pumps, don't count on the O rings to seal, you're going to need some RTV!
I can make a pass in 100 degree heat, pull into the pits at 210 water temp and run the pump and radiator fan and in 10-15 minutes the water is at 140 degrees!
https://www.summitracing.com/parts/sum-316005
Thanks! I have a small power master alternator, I'm planning to use the water pump that mounts in the housing or a remote pump.This is what i use
https://www.summitracing.com/parts/mor-63750
standard mopar alt.
Pull back into the pits, shut of eng put battery charger on. fan and pump temp controlled. A couple minutes and fan shuts off,10 minutes water pump shuts off.
Mine hasn't been tested in high heat.(90*f is a heat wave up here.)
These are great if you have the kind of water pump that has a removable pulley. The genIII hemi ones are press fit :-(This is what i use
standard mopar alt.
https://www.summitracing.com/parts/cbc-dy-1420/overview/What does your charging system consists of?
