Electrical connectors for 66 model year
Miranthis
Shawnee, Kansas
Does anyone make or have a catalog of electrical connectors I don't see them in the electrical or standard parts sections of the service manual for 66. I need to replace one or two, specifically the wiring harness for the turn signals in the steering column. I would like to de-pin and replace the connector if possible.
The turn signal connector packages are 2495541 female side, and 2585030 male side.
Thanks. With the part NUMBER now i can find it in the parts manual.....:thumbsup: I was off looking for a list with drawings of the various connectors.... Appreciate it.
Does one of the repro companies make them? Just the connectors and terminals, that is.
The companies that make reproduction wiring harnesses must be getting them from somewhere.....or making them themselves.
If you are referring to this connector its available thru quite a few vendors.
63-69 turn signal connector.
The factory one on mine had the retaining pins that snap into the column broke off.
The original was 2 piece construction so you could slide it off without removing the snapped in part from column.
The new one was 1 piece, and if you want to remove it from the column you will most likely bust at least 1 tab.
I got my repo from the mopar shop but they all look like 1 piece construction on the repops.
