OK, so it is fixed !!! :toothy7:
Thanks so much to everyones help, it sure helped me find the problem.
It turned out to ba a bad splice in one of the wires from the regulator. The wire to the alternator was fine, the other one had been spliced sometime in the past (before I owned it) and had come apart causing the alternator to charge fully. Such an easy troubleshoot when its expalined what to look for and you use a mutimeter.
Thanks again to everyone for the help.............now, if only someone could come up with a way to make the the lifters/rockers more quiet :banghead:
