Electrical Help Needed
67ragtop
Buffalo,New York
When I turn the ignition off in my 1967 Barracuda sometimes the blower switch for the heater stays on. If I turn the key on and off a few times the blower motor for the heater will eventually shut off. Is it a ground to the ignition? A bad ignition switch? Or should I be looking for a wire between the ignition and the blower switch? Thanks in advance.
sounds like a bad ignition switch. When the blower stays on do the wipers, blinkers, radio, etc.., stay on ?
Good job! Redfish to the rescue again!! I may have a switch if you are interested, as long as 67-69 are the same
Steve
they aren't all the same. I dont recall transision years.
What should I do. He told them it was for a 1968 barracuda and it took three days from the warehouse. How can I tell?
remove neg' battery cable, remove the bezel nut , move the switch out from under the dash and compare the harness connecters.
