My Dart started having some sort of issue today. I suspected that the alternator was going, because the car wasn't running very well, and I kept having to boost it. I borrowed a battery charger last night and charged the battery fully, which was enough to go around town a couple times today and get gas.
Now I don't have a dome light or any ignition at all. The only way I've been able to start the car, or get anything electrical to work at all, is to have the positive clamp from the battery charger hooked to the battery. Even with the charger off, and the negative off, the car will start and run with the clamp on. Once I remove it, the engine dies and so does everything electrical.
I tried tightening the battery terminal with no change. The battery and terminals are brand new, there is no corrosion.
Any suggestions?
I took a video of the phenomenon:
[ame="https://www.youtube.com/watch?v=CHxeI4D7lac&feature=youtu.be"]VID 20150818 192037 - YouTube[/ame]
Any suggestions?
