^^That is absolutely on the list. Make some tests. Get it warm and running
"Wiggle" the ignition connectors........distributor, ECU (unscrew it) ballast. Wiggle the bulkhead connector, too
Measure running coil voltage. With battery up warm and normal, battery should be close to 14. At that voltage the coil + will vary, but should be somewhere around 10-11 volts
Suspect the tach or tach wire, so unhook them for awhile.
Make CERTAIN the ECU is grounded. Remove it clean around the bolt holes, and remount, using star washers
Inspect the interior of the cap and the rotor. Inspect the pickup / reluctor, for strike damage, rust, debri, and wiggle the shaft.
Get a .008" (inches not metric) brass feeler. O'Reallys did have these. Set the reluctor gap and check shaft play.
ESPECIALLY "work" the distributor connector in/ out several times to scrub the terminals and feel for tight.
