i've welded, changed springs and recurved many distributors,this is going nowhere.
Your 100 % correct...i'm done.
Then why the questions about the curve, or statements that there is no issue with the curve (good curve), if you know what you are doing? Pot stirring?
You KNOW this thing is a POS in OOTB form yet still ask questions about advance at 950rpm which is irrelevant. That's part of the shitty 26*. If you like to run your stuff with so little initial timing, then it's not running as well as it could, simple as that.
Another reason I tend to not post as much around here.
