gg73
New Member
Hi guys, I know this topic has been covered a lot but I have spent two weeks looking for an answer and I can’t find it. I installed a ProForm electronic ignition kit two weeks ago. New distributer, ecu, harness and coil. The car will start then immediately shut down as soon as I release the key from start position. I have narrows it down to my ballast resistor because I have 12 volts going in, but only 1.5 coming out. If I use a jumper wire and put 12 volts directly to the coil the car starts and runs. I contacted Proform ( who are very difficult to reach ) and they agreed with me and sent me another ballast resistor. I installed the new one and still have the same problem. I have two questions: Do they make different ballast resistors with less resistance? 2nd question is do I even need a ballast resistor? I installed a new MSD Blaster 2 coil if that matters. Any help would greatly appreciated.
