yes 73 was the first year i believe. if you get a used dist. make sure you replace the plastic drive gear on it. can probably get a rebuilt dist from a parts store pretty cheap.
real easy hook up. blue wire with yellow tracer goes to the ballast key power side. and the black with yellow tracer goes to the -coil. the rest is common sense..
