The wiring from the ignition run to the voltage regulator field junction (goes to 1 side of the field and jumps to the voltage regular blue wire) melted to ****. I noticed it because I went to swap let's in my carb and there it was. Fortunately I was close to home so I grabbed a known good alternator and voltage regulator from a running driving daily driver truck and swapped them on to my car. I replaced all the melted wiring right to the junction point with the ignition run wiring. I also replaced the wiring plug on the voltage regulator because I had one.
I didn't have time to properly diagnose, So I shot the parts cannon at it but it still does not charge. I have 12.24 v at the battery, 12.12 v at both sides of the alternator field ehen running. It does not increase with RPM. What am I missing? What voltage should I read at either side of the field terminals?
Cley
Cley
