Beatnik
Hey guys and gals, since re-wiring the Duster I salvaged all the good stuff off the old harness. Figure I'd see if anyone needs any of these for spares or to replace a bad one etc...
Some individual pics below, sorry for multiple pic posts but couldn't get em all in my orig post with the IPhone. The black you see on some of the wires is residual electrical tape adhesive.
$20 shipped for all 5! Would like to sell as a lot, keep it simple.
From left to right:
- complete fusible link w/ round style connector and 30" of wire to go from starter relay to bulkhead connector
- Electronic ECU connector with dual pin style ballast wires
- '70 up style electronic voltage regulator connector
- Water temp sensor connector
- Keyed ignition at starter relay connector
All have a nice run of good wire on them to splice with. If any of these connectors or wires on your car are toasty these will do the trick. Or again, good spares for when one finally does decide to kick the bucket and fry itself.
Thanks FABO!
From left to right:
Thanks FABO!
