pettybludart
I had a similar incident when I first bought my car.PO barely drove the car maybe 3 times a year.When i got the car it would overheat every 15 mins.Then 1 frost plug leak under headder d.side.Fixed that,then another,fixed that,then heater core(replaced)rad was plugged(replaced)backed the car out and shut the garage door,turned and noticed drips.Well now this was at the back.F. this I,m yanking the motor.Got motor stroked everything is fine now.Apparently P.O never changed anti-freeze in over 10 years.Old a-freeze rotted frost plugs from inside out and the P.O was useing barz-leak stop to band-aid the leaks.All aside I spent a good # of hours chasing frostplug leaks.Also replaced with brass ones.Sorry for long winded story.Hope you have no other problems.
