FJ5
I'm building my first engine. 408 stroker based off of a 2000 5.9 magnum. What I have is
RHS Indy X heads with 2.02 valves. stainless steel roller rockers from hughes PN 1550. ARP rocker studs with Edelbrock guide plates.
Now 2 questions
Are the intake valves supposed to sit lower in the head? To explain... if i set a straight edge on the valve stems across the all the valves the intakes are all lower and not all the same amount. I'm talking like a 1/16"
question 2
the roller on one of the intake valves only contacts the stem on one side of the middle portion of the valve stem. is this a normal acceptance or is this not acceptable?
Now 2 questions
question 2
