71DartGuy
All right guys, I need some advice. As you can see from my avatar, I own a /6 71 dart. I'm in the process of upgrading to disk brakes, swapping out the 7.25 for an 8.25, and adding a 727. The question is, what would be the most economical way to get a small block making around 400 horsepower into this thing. I would really like to build a motor versus buying a crate. I've seen articles with buildups of everything from a 400 hp, zero deck 318 with magnum heads to a 537 hp zero deck 360 that runs on pump gas. Only downfall in my opinion is a solid cam. I wouldnt think that 400 hp is a very hard number to achieve with 10:1 compression and a good set of heads. I'd like to know what yall are builiding or what you have had success with in the past. Oh, a few things that may help. The car wont be a "daily" driver but will be driven quite bit (mostly on the weekends to cruise ins and shows) It will have manual brakes, 3.31 posi rear, 27 inch tires.
