SRT_DSTRHOLC
So were trying to pull the engine and trans separate, but the engine is getting stuck on the snout of the converter. Any idea what to do? and what to do when putting it back in?
did you unbolt the TQ from the flexplate?
Not good!If the converter slid out and got hooked on the back of the engine,even just bya 1/2 inch.You probably cracked the snout.JMO.Going back in,make sure the convertor is seated all the way in.Lift and spin in til you feel it move in another 1/2 inch.Good luck.So were trying to pull the engine and trans separate, but the engine is getting stuck on the snout of the converter. Any idea what to do? and what to do when putting it back in?
I would never be able to pull just the motor out of my dart (426 hemi) do yourself a favor and pull trany too. Sometimes it makes thing alot easier to do a little more.
