Old Man Mopar
Righteous Dude
Great picture.....and didn't even have to remove the bumper like I had stated from memory.View attachment 1715108573 Works good dropping out the bottom. I just made a dolly out of 2x4’s and some caster wheels
Yeah that's what I was thinking. It only cost me $1795.00 2 years ago and I use it at least a couple of times each month.Very nice and not really very expensive for the use you will get out of it.
I just retired from a Chevy/Toyota dealer service facility where over the last couple of years we systematically replaced two dozen older lifts. Very economical and they sit on top of the floor (no pits) so if you ever have to move them it is pretty easy.Yeah that's what I was thinking.
Yeah and they're easy to install. My buddy and me installed mine in one afternoon. They spec 4" thick concrete with a minimum of 3000 PSI. I have 4" thick (6 inches at the uprights) and it's rated at 4000 PSI. Just get a brand new high quality drill bit and use a shop vac to keep the dust out of the hole while drilling.. I also (even though it wasn't required) used a cement epoxy on the bolts.I just retired from a Chevy/Toyota dealer service facility where over the last couple of years we systematically replaced two dozen older lifts. Very economical and they sit on top of the floor (no pits) so if you ever have to move them it is pretty easy.
What exactly did you hook to on the body to lift it?View attachment 1715108573 Works good dropping out the bottom. I just made a dolly out of 2x4’s and some caster wheels
Make sure you get proper training and instructions before using your lift.Got tired of rolling around on the ground. When I built my new garage I put 12 ft walls in and installed a lift, it's always been a dream of mine.View attachment 1715108587
LMAOMake sure you get proper training and instructions before using your lift.
Lol Wow, can't believe that anyone that had a lift would be stupid enough to do that!Make sure you get proper training and instructions before using your lift.
You will be so glad you did. Remember to put the back wheels up on some ramps or blocks; It's a lot easier to tilt the car up and to maneuver the engine out so you can roll it away.Well you guys have changed my thinking, out the bottom it is. It just makes more sense the more I think about it. Thank you!
You are WRONG. Out the top will never be as easy and damage free as out the bottom. When you remove it from the bottom you're not "pulling it"; you're leaving it set there while you pick an extremely light portion of the car up off of it.Well, WCMachine, If you are not confused by now, you never will be. Here is my opinion. As suggested by crewchief, use the carb base plate and pull the engine and tranny at the same time. You can "borrow" a carb base plate at most box car parts stores. The people saying to lift body and leave engine on K Frame may not be thinking about a guy pulling an engine for the first time. I've been doing this for a LONG time, and as cool as it would be, I haven't done it like that yet. You will need a helper to help pull the engine forward as it comes out (via yanking the crane forward), and to lift the tranny tail over the car's nose as it comes out. Easy peasy lemon squeezy. I wish you lived close to me, I'd come over to help.
Great thanks. I figured the 5/16 would be strong enough as long as they were tight.
100% correct sir. I know you've seen me preach the same thing, only to be tarred and feathered.
I wont argue. I guess I'm just a creature of habit. Maybe I'll force myself to try it like that one day, but I've never had a problem "Pulling". Although I must admit that every time the engine is perched high above the nose of the car, I say, "hydraulic seals, please don't fail now."You are WRONG. Out the top will never be as easy and damage free as out the bottom. When you remove it from the bottom you're not "pulling it"; you're leaving it set there while you pick an extremely light portion of the car up off of it.
The steering coupler, the torsion bars, and upper control arms. I still can't see taking the front end off and not getting an alignment?
