ken5124
65 Valiant Signet
My 318 seems to be misfiring. It is a professionally built motor, mild cam (supposed to get me 300 hp), mopar alum intake, edelbrock avs carb, fbo ignition system, running hooker long tube headers, 2 1/2 inch exhaust. New schumacher motor and trans mounts and a torque strap. This motor has 4200 km on it, and has done this vibration( i think it's misfiring ) since it was new.. I have replaced rear axles, driveshaft twice, torque convertor( it's the right one for the motor and my 904 transmission), and harmonic balancer already. The entire car has been re wired.
It does this whether driving or sitting in the garage. If I rev the motor up while looking at it, it starts to physically shake at about 1400 rpm and is most pronounced at 1800. While driving 1800 rpm's is where I really feel it, whether light accelerating, cruising or coasting.Under hard acceleration I can't seem to feel it.
It is driving me nuts. I have checked and replaced plugs, wires, double and triple checked timing. It doesn't seem to matter if I hook up the vacuum advance or not. I have unhooked portions of the exhaust to see if somehow that is causing the problem.
My gut feeling is that despite being a tested distributor, perhaps it is just not right..
Help!! or if you live in Manitoba.. come on over and see and feel this shaking for yourself!! Any ideas???
