just installed an Msd 6al box with an msd blaster 2 coil and it cut down the shaking probably by about 50-60%... I was not expecting this improvement so this makes me think it's potentially something with the spark plugs/ignition. Any ideas on how to remedy this
It's
probably NOT the ignition.
It
Probably is a poor Idle-AFR,
And the Multi-Strike is re-lighting the fire up to 20 times per revolution.
Fix the Idle-AFR, and the shake will go away.
A big cam always wants additional air. The usual response is to crank up the idle-speed screw. And then the engine gets TOO MUCH fuel from the transfers. So the response to that is to close the mixture screws. But now the Idle speed is too fast, and the response to that is to take away timing. In the end it gets all messed up.
So then, your tuner figures it out and allows the extra air in somewhere else, usually by cracking the secondary blades open.
This allows putting the front back to normal, with additional timing; BUT the dry air entering the secondaries makes the back 4 cylinders go lean, resulting in the shake. and the response to that is to richen up the primaries, making the front 4 cylinders rich, resulting still, in a shake.
In any case, unless you back up the bus and start over by adding the fuel into the Bypass-Air, the result is a rough and usually stinky idle.
Your first defense against this is to have a correctly plumbed and good-working PCV system.
I only tune SBMs, and the biggest cam I have tuned is the 292/292/108 Mopar cam. IIRC; 248@.050. Yeah ok those tend to shake at 550 rpm, lol. But by 750. tuned right, they get to running comparatively smooth, even without a Multi-Strike.
But, ya know what? Because this is a relatively unknown deal, I would start with the basics; and that means a compression test. Which might lead to a LeakDown test. And of course, looking for vacuum leaks, specifically into just one or two ports, and it could be from the bottom, who knows.
And; if you have a big cam,AND a single-plane intake, you really have to have headers; cuz logs can make big trouble.
