AJ/FormS
68 Formua-S fastback clone 367/A833/GVod/3.55s
- Joined
- Jan 19, 2014
- Messages
- 26,614
- Reaction score
- 13,851
That's a problem.No ignition timing changes since after I installed the digital box. I just converted to it yesterday.
You may not have changed the timing by moving the distributor,
but the box did, electronically.
And yes, the MSD needs a MSD specific timing lite, or a lite that can grab the first firing, or you can set the timing AFTER the multi-strike drops out, usually around 3000 rpm, which is actually the better idea.
But as the guys have said; your first move is to prove the index mark on the damper is where it belongs.
