[SOLD] Engine, transmission, and misc.
Dicer
70 Swinger
Land of Lincoln
Clean-Up on isle Six
Fall cleanup getting a tired of moving parts and pieces around the shop. All for one price of $3000 dollars OR best offer.
The motor show is 1972, 318 out of a Dart Swinger, fresh overhaul about 6 hours run time on the stand at varying rpm.
watch here>>>>>>>
30 thousand on piston bore
10 on rod journals, crank mains stock
Heads redone 4 exhaust valves and stem seals
Cam and lifter set Mellings CL-MTD-1
Oil pump Mellings M-72HV high volume
Engine timing set Mellings 40202
Pistons .30 stock From Summit
Manifold Edelbrock D4B with Edelbrock 650 w/Electric choke
HEI upgrade and eCoil Clear distributor cap (lol)
Cam bearings and freeze plugs, oil pump shaft and bushing replace along all oil gallery plugs.
90 degree oil adapter
This I used for a test mule, different carbs and tried different disturbers and timing advances. Now it’s set for no vacuum with mechanical lock plate
On this pallet: ALL A BODY…2 Bells, Steel and cast, 4 speed transmission, Flywheel and clutch pack, motor mounts, starter, test run pipes, shock mounts, leaf shackles, stock shocks, exhaust tips, fork arm, z bar, bell cover and heads (2658920)
Next pallet: 2 timing covers and fuel pumps, horns, headers, 2 oil pumps one with pickup screen, 2 sets of used lifters (318,340) 340 valve springs, oil pan, 340 camshaft (looks to be a Crane Fireball)? Trash container full of 69 Dart parts, wire harness, window regulators, mirrors, wiper linkage, e cables and eBrake handle, and more I am sure.
PM me if you have questions, can help load. Harvest time is here, so my daylight hours limited. Located in the center of Illinois, my zip code is 62671
Oh Yes the pictures...oops
