dustoff440
I'm puttting a motor together- 1992 360 magnum roller, stock bottom end, hughes cam .544 lift intake and exhaust, 218@.050 intake, 228@.050 on a 106 degree, sweet spot 2300-6100 rpm ,with stock heads, mopar M1 dual plane, and a thermoquad put together by Demon Sizzler, and headers. 904 with a 3500 converter, reverse valve body and 3.91 out back on a 25 inch tire . I also will install an MSD with adjustable timing for both rate and amount of advance and with retard for the 150 nitrous shot. My goal is to have very crisp throttle response so I can fry the tires at will. Is there a "Nitrous for Dummies" or something like that
out there I don't really want' to mail order a book without knowing something about the book. Thanks
