Espo +2" springs
i'm looking at the space between the top of the tire and wheel well. driveway looks sloped big time too.
What backspace do your wheels have? 15x8's? They look like they fill the wheelwell pretty good in your avatar pic.
Wheels on it are rollers, I haven't ordered my new ones yet, I have to get my 8.8 installed so I can measure for Wheels, it's being shortened 3 inches.
For starters, find some level ground for pics.
Looking at the car, the rear sits nice. Get some 60 series tires on the front, and drop it an 1". Go to go.
I can take some tonight she is in the garage so it's level, I just wanted that 70s drag car (stink bug) look.
I was talking to the original poster.
Jumping in on others posts only muddy's the water.
For better results, you should start your own thread. :thumbsup:
I hit the like button . I have 295 60 d15`s on my fastback , the caltrac monoleafs have settled to where the top of the tire is about 1'' up inside the fender well , looks great and darn near sits level. Just had to build/add a .044 shim for one side to stop it from barely rubbing on the inside fender well on pass. side.
Do you have some pics and part numbers? I would really like to get an idea of what my fastback will look like, my plans also call for the caltracs and their monoleafs.
if you want it to handle properly leave it at stock height or lower it a bit.
But you didn't want to hear that.
LOL , w/ a caltrac rear and a magnum force front end , mine dont handle worth a s--- ! but it only weighs 3300 pounds .
I have already moded the orig k member for my big 9 qt pan , just need to find a complete disc brake set up for it "and the $$ to pay for it''.
No, on part #`s , bought everything off of guys on this site , and made them work / offset spring hangars , that a guy said wouldnt work on his A body, massaged the inner fender wells, "from past experiance'' before I bought the tires , stretched the front of the fender wells to the inner fender , have the same contour as stock. before the springs settled ----------------------------------------------295 65 15 drag radials
second pic is 295 60 d15 treaded slicks, work on 8-10'' rims , these are 8`s---------------------------4 1/2'' offset , shimmed w/ spacers , really need 4''. tire is about an 1'' up in fender well now.
No, on part #`s , bought everything off of guys on this site , and made them work / offset spring hangars , that a guy said wouldnt work on his A body, massaged the inner fender wells, "from past experiance'' before I bought the tires , stretched the front of the fender wells to the inner fender , have the same contour as stock. before the springs settled ----------------------------------------------295 65 15 drag radials View attachment 1715628120
View attachment 1715628120 View attachment 1715628131
sorry about double pics, sure had a hard time bringing the second pic up , musta done something wrong !
