I recently bought 2 more old OMC outboards, a 55 5 1/2HP and a 55 10HP. They need "the usual suspects." For ignition this means plug wires although for now I'm leaving the old until I evaluate the motors, new points although those are the old ones--filed and dressed, until evaluation
And they needed new coils and condensers. These are "orange drop" poly caps which I had a few off in the right cap. range, .25ufd
The one set of condensers, sawed the tops off, and the guts fell right out. So I just drilled a hole in the bottom, fed the cap lead in through the hole, and soldered it for the ground. Then pumped some hot glue into the "tub" to hold it in place
The second set were "tarred?" inside and could not get the guts out of the tube, so I heated them with an LP torch. I thought the brackets were spot welded but they were soldered so they fell apart. At first I thought I'd solder the tubes back onto the brackets, but instead, I bent on cap lead around the bracket and soldered it for the ground, then just heat shrinked the cap to the bracket.
"We'll see.............."
