Your kidding, right?
The factory never does easy stuff like that for us. Factory roller rockers will not work in early blocks, if they did way more people would use them. And likely aftermarket roller rockers would be cheaper. The lifter bores need brass bushings installed, around $550. Block needs to be strip and clean also. Even then only aftermarket roller rockers would work
I am sure you meant factory roller lifter will not fit the early block...
LA blocks do not need to have their lifter bores bushed to run roller lifters...
aftermarket lifters are a drop in, no machining necessary.Yes factory rollers will not fit the early blocks , oh, but some blocks the lifter bores can be cut low on one or more bores. Maybe the aftermarket has solved this problem. Don't the block still need some grinding? Its not a drop in, motor in the car cam change thing-right?
